Results 31 to 37 of 37
Thread: Simplify3D
11-30-2016, 01:50 PM #31
- Nov 2016
- Earth
- 28
OK, my impression is that this is, by a reasonable margin the best slicing software available. Is there a slicer that would be better for learning? More intuitive?
I can ignore complexity if otherwise the interface is well laid out and intuitive to use. It is hard to work around a bad UI.
11-30-2016, 02:37 PM #32
I'd say cura is probably the next best option to simplify3d. And it's free :-)
has most of the options and easy to use.
11-30-2016, 03:28 PM #33
- Apr 2015
- Northern Ohio
- 198
12-10-2016, 07:32 PM #34
- Apr 2014
- Echuca Victoria
- 60
Hi All,
Just purchased this software last night ( didn't make it to bed and now 12:30 pm ), cant believe how much better the print quality is, and the bed adhesion is brilliant. My only issue with it is that when doing any print with support structures, the supports leave massive scarring / burning / deforming of the print wherever a support is used, everywhere else on the print is beyond excellent.
Has anyone else had this issue, or is there a setting in supports that I have missed. Using 2 Flashforge creator Pro`s and both creating same issue.
Thanks in advance
Steve
12-11-2016, 02:00 AM #35
- Sep 2014
- Brummen, Netherlands
- 265
The scarring depends on the type of plastic, PETG is really bad, PLA a bit better and ABS the best of all.
In the support tab you can specify how many layers to leave free between support and part. Normally it is 1, but you can set it to 2 and see how that works.
12-11-2016, 02:15 AM #36
- Apr 2014
- Echuca Victoria
- 60
12-22-2016, 10:37 PM #37
- Dec 2016
- 6
Simply3d should be the most powerful slicer I ever used
Printing time- Is this right?
