Results 1 to 10 of 10
Thread: Clicking started after cleaning.
12-07-2016, 02:03 PM #9
I had symptoms similar to yours, TJ. Cleaned out the nozzle (even redrilled it), replace the PTFE tube, you name it, I did it. The clicking continued. Turns I was was using bad filament. Switched brands and the clicking stopped.
At this point you probably already know that you either have a heat issue (not enough heat getting to the nozzle) or your filament is bad.
