12-05-2016, 03:14 PM #1
- Dec 2016
Modeling Mesh from Solid for 3D Printed "Fabric"
Hello,
I would like to print a model with a structure that resembles this pattern. It doesn't have to be as flexible, it's just about the looks.
I already have the solid model built in Maya, I just need to find a way to "fill" it with the structure. Searching the web, I have found several 3d models of similar "fabric sheets" and Meshmixer's built-in "pattern" functionalities which are very restricted though.... so definitely not what I was looking for.
Could you help me? Thanks!
12-06-2016, 05:05 AM #2
well as far as I know all the plastic 'fabrics' on thingiverse - and there are quite a lot. Have been done with openscad.
It handles the precision and iterations better than most things.
12-07-2016, 05:37 AM #3
Typically meshes aren't 'modeled' but are the result of a process. If you are hell-bent on modelling it then just about any software should be able to do it (pro software that is, don't know about the free stuff) but you will hit CPU/RAM limits. Not to mention the time taken to do it.
