Results 1 to 10 of 139
Thread: Open Sourcing the Pegasus
12-05-2016, 12:15 PM #15
- Jan 2016
- 121
I thank you for the offer, I'll try to send you my address shortly. The firmware does work fairly well last I ran it, I know a few things I need to tweak, but whatever I publish in the end will still need to be calibrated to your printer and specific resins. I hope to have better details on how to do this, as of right now I'll have a bit of time around the up coming holiday's. I also have the issue that even when I was using FSL's firmware the printer didn't work very well in the winter as my house generally isn't warm enough. I moved the printer to a warmer area of the house and it's a smaller room so I can easily heat it a little bit warmer if needed.
That sounds very cool about the porcelin resin? Do you know how much energy it requires to set it? That might give me an idea on how to adjust the calibration for you.
/Jason
