Thread: Separating Resin from Salt Water
10-20-2013, 09:50 AM #1
- 26
I know there has been many questions on how to separate Resin from Salt water
I know Resin and salt water is very similar to how when Oil and water are put together they separate into different levels according to there density in a beaker.
I know resin's properties are way different than oil but this might still work the same way even though they are different materials.
In the video they use a special cloth membrane to separate the oil from the water using superhydrophilic–superoleophobic properties.
I'm not 100% sure this would work exactly the same but it might do something similar with the resin and the Salt Water.
Or just use a simple turkey baster to suck out the resin from the water that could work too !!!
10-20-2013, 09:58 AM #2
- 26
I'm not 100% sure of this ethor so do not take my word for it perhaps this filter was created using Neverwet spray which is a superhydrophilic spray which was sprayed upon some sort of cloth or paper which was used to create a filter to separate oil from water.
New member with print issue
