Results 11 to 13 of 13
11-22-2016, 08:37 PM #11
@curious aardvark
Thanks for chiming in!
Yes, we are offering support for Simplify 3D. As for printing materials with different print temperatures, so far we have printed dissimilar materials at a fixed temperature that works for both. However, we look forward to experimenting with printing materials at significantly different temperatures by allowing temperature changes during filament purging.
05-14-2017, 10:51 AM #12
- Oct 2016
Even dual nozzle solutions require a bit of purging because the molten plastic slowly drips out of one nozzle (and creates messy lines all over your print!) while the other nozzle is printing. In order to reestablish hot end pressure, you need to purge a bit of filament.
05-25-2017, 09:12 AM #13
You'd think so wouldn't you.
watch this video:
No visible contamination, no purge pillars. Not a needle valve dual print nozzle. two actual seperate nozzles.
How the hell is that working ?
