Originally Posted by
uncle_bob
Hi
I am setting it up right now on a 12" Pegasus. Once I get that running I will transfer it to the 10" Pegasus. The BL Touch is mounted to a custom extruder I came up with. It also holds mount and duct for the cooling fan. Once they both are done, they also will have dedicated +5 supplies and Rpi's to run them remotely.
I'm not real sure how much use my firmware will be to others. I'm running a SSR on the heated bed and the filament cooling fan. I have the bed offset a bit to the right of the location MakerFarm recommends. My bed limits don't work very well on a "standard" printer. They are great for doing stuff that is a bit larger than the bed. Another part of that trick is the thinner power supply that I use.
Once I get it all done I'll toss it up somewhere.
Lots of fun...
Bob
