Results 11 to 13 of 13
11-14-2016, 04:53 PM #11
- Aug 2016
- 29
You mean grabbing the carriages where the bars slide into? Going to give it a go in a few. Thanks for your help.
11-15-2016, 05:56 AM #12
- Jun 2016
- Oklahoma
- 904
Try to hold one side, I do the right side, still and then move the other side forward or backward as needed. It will resist but then when it goes you will hear the belt skipping teeth. Go a little at a time.
I then let it print a line close to the front edge to use a s a guide for parallel.
11-15-2016, 09:20 AM #13
- Aug 2016
- 29
Fixed it
Thanks for your help!
New member with print issue
