Results 1 to 10 of 29
11-09-2016, 03:44 PM #11
Install it so it can run on your machine????
The source code was given so you could learn. The very first line of the do_fill() module is:
Code:module do_fill() { translate([-7,-14,0]) import("fibofidget.stl");
To proceed, you would make a source file called do_fill.scad in some directory. Put that code into the file do_fill.scad. Put the original .STL file (with the correct name of fibofidget.stl) in the same directory. Double click on the do_fill.scad file from within Windows Explorer. That will bring up OpenScad. You should see an initial rendering of the output at that point.
