Results 11 to 15 of 15
Thread: PCL (Polycaprolactone) printed
11-09-2016, 12:03 AM #11
- Nov 2016
PCL can be mixed with carbon black to make a printable conductive filament called carbomorph, as described in this paper: A Simple, Low-Cost Conductive Composite Material for 3D Printing of Electronic Sensors.
-Unrelated info removed and referenced article located:
http://journals.plos.org/plosone/article?id=10.1371/journal.pone.0049365
-DavoLast edited by Davo; 11-09-2016 at 06:16 AM.
11-15-2016, 08:00 AM #12
We just melt the pellets and print with that. We don't create filament. Sorry.
Our MK1-250 head has a spring loaded bearing assembly to keep the filament snug against the hobbed motor shaft, which allows for variances in diameter. We can usually run filament between 1.6 and 1.9mm.
11-15-2016, 08:33 AM #13
No, we communicate over CANBUS, and I'm unaware of other printers doing so.
The MK2-250 is great for flexible filaments, but the shafts are in fixed positions, so it is less adaptable to variations in filament diameter.
11-15-2016, 12:28 PM #14
Sorry, no. The only extruders that I've heard of with reliable, consistent diameter output cost too much for most home users.
03-27-2017, 07:31 AM #15
- Mar 2017
Hi RonJon,
Would you please share some of your settings to properly print PCL filament (speed, extrusion temperature , etc) ? What do you mean with 'aftermarket modrifications' ?
I also make homemade PCL filament from pellets with the filastruder: I obtain a rather fine 1,75 mm filament at a 70-80°C temp. The molecular weight of PCL might be of importance regarding the viscosity of the flow, mine is around 80,000.
Unfortunately I have troubles printing the PCL filament using my FDM Volumic printer (it is based on a J-head); I had some encouraging results at a 128°C extrusion temperature, but now I have the same problem than you with the filament not being pushed in, so I would be so happy with some advices making it run like a Cadillac ;-)
