Results 11 to 13 of 13
Thread: Speed vs quality
10-29-2016, 07:11 AM #11
can I suggest something to you.
Learn to use an internet search engine.
Most of the smooth models you see are produced either by sls on powdered nylon or sla with resins. No comparison to fdm, appearance wise.
Also pretty much every question you ask can be easily answered by a short internet search.
Is there currently much selection in nozzle diameter for consumer devices? Does it make sense to change between arbitrary diameter eg. via a quick change system like on newer Ultimakers? I mean would there be issues with filament feeding or other parts of the moving print head - obviously travel speeds etc could be an issue with fine&fast printing if the printer is not designed and built with that in mind.
yes, lots of available nozzles.
Quick change systems are good
The slicer handles most of the changes - as long as you tell it the nozzle diameter.
10-29-2016, 05:02 PM #12
- Oct 2016
- 16
I agree that Google is rather indispensable. (They should prolly teach search engines in every school.) But it's got its disadvantages and I think best works when you need some specific knowledge, or are very new to some subject and/or get very lucky
As to nozzle availability, you can search "3d printer nozzle upgrade diameter" in 3 minutes, and then start filtering the results. There will be many that are just irrelevant, some which look interesting but turn out to be very unhelpful when you read them, some articles you need to read but probably learn little of the actual search subject while picking up a small bunch of related knowledge. Here's a pretty good one on nozzle diameter selection and speed:
https://craftunique.com/forums/view-thread/1254
But actually it discusses just one printer though some of the observations of course must apply universally. From the titles you may conclude that yes, there is availability of different nozzle sizes but since it's almost always for a specific printer, you're not quite sure if it's 10% or 80% of the market since there are hundreds (thousands?) of different printers. Then there's also the outdated ones from 2013 or so. All of it takes easily a few hours and still I end up with some unread articles cluttering my browser.
One article states about nozzle size and speed:
[COLOR=rgba(90, 90, 90, 0.901961)]After installing the 0.8mm filament, we’ve been able to push this up to [/COLOR][COLOR=rgba(90, 90, 90, 0.901961)]20mm^3/s[/COLOR][COLOR=rgba(90, 90, 90, 0.901961)] and potentially higher by printing at 0.5mm layer height at 50mm/s. On a practical level, this means that we can now print a low resolution version of this cute octopus model in 27 minutes instead of the 3 hours estimated under our previous settings. Printing with substantially higher layer height required that we recalibrate the bed to a somewhat farther distance, but was otherwise very straightforward. The filament used here is Colorfabb Leaf Green PLA/PHA, which we’ve had very good luck with.[/COLOR]
For fine print models I meant stuff like this from Ultimaker 2:
https://3dhubs.s3-eu-west-1.amazonaw...er%202%204.JPG
The thread is hardly visible at all - a far cry from what I created with the Ultimaker original (and 200 layer).
10-30-2016, 07:09 AM #13
nozzles are available for specific extruders - not necessarily specific printers.
For example you can add an e3d hotend to most printers and they will then use the same nozzles.
It is actually a pita, try finding an original brass nozzle for a mk8 extruder - nigh on impossible.
So while there are always different nozzles available for all extruders, some of the older models can be harder to find.
Nice marvin - do you have a cooling fan blowing on your print area ?
The loop on marvin's head isn't great, looks like it could do with some cooling.
But yep - that is very fine detail.
Honestly I would never bother with that kind of layer resolution. But I rarely print decorative figures :-)
They say life is too short to stuff amushroom - I say it depends on jow big the mushroom is.
But life is definitely too short to print at 0.05mm layer resolution :-)
