Thread: bottom's up! Need help.
10-16-2016, 10:06 PM #1
- Aug 2016
- 59
hi all. i am using simplify3d and love it but i ran into a problem printing. i seem to have to use a raft for most prints but it takes longer to print. so i tried to use a brim instead without a raft. i am using pla inland brand for this. problem is when i use a brim and not a raft the bottom comes out terrible.
is there a way to use a brim and still have the bottom of the print come out nice?
thanks
10-17-2016, 05:14 AM #2
Take a look at you nozzle height calibration and first layer width. Get it closer to the bed with a bitter extra width and it will press the first layer against your build plate, making the bottom layer smooth.
10-17-2016, 05:45 AM #3
what's supposed to be wrong with that print ?
And what material are you printing on ? that's what makes the difference.
And what idig said too :-)
A lot of people seem to print with a very loose calibration, ie: a fairly large gap between the printhead and the print surface. To get a good stick and smooth print the first print layer needs to be smooshed onto the printsurface.
10-17-2016, 06:30 AM #4
- Aug 2016
- 59
thanks again for your help!!!
the PROBLEM is bottom is very rough and not smooth. i wanted the bottom to match the top in consistency. i am printing on a non heated bed using glue stick for adhesion.
i did calibrate the printer but it didnt seem to help. i have the nozzle smooshing onto the bed with the ability of me sliding a piece of paper under the nozzle with a little friction but again it didnt help the bottom of my print come out good.
not sure what to try and what i should change in the s3d settings... [thanks]:
10-17-2016, 01:59 PM #5
10-17-2016, 02:49 PM #6
- Aug 2016
- 59
Yes, i did calibrate the printer but it didnt seem to help. i have the nozzle smooshing onto the bed with the ability for me to slide a piece of paper under the nozzle with a little friction but again it didnt help the bottom of the print to come out better.
not sure what settings to manipulate besides:
increasing extrusion multiplier
infill %
thanks
