Results 2,921 to 2,930 of 4110
08-24-2016, 09:20 AM #2921
Dual color extrusion isn't used much in reality. It is nice to have the capability though. The last dual color print I did with one nozzle, just paused and switched out filament. On that particular design it made more sense to do it that way since only the top layer was the second color.
08-24-2016, 10:02 AM #2922
- Feb 2016
- 360
I finish and paint probably 80% of what I print.
I use right side extruder...left side stepper is sitting on the shelf lol. No point running the extra weight if you not gonna use it.
Just keep in mind the the right side stepper is what hits the limit switch, so if you plan on using left side only you will need to make a shim to hit the limiter.
Dual color extrusion is kinda gimmicky imo. It is a selling point for the machine rather than a practical feature.
One of the reasons I still wanna sell and get some single nozzle machines.
08-24-2016, 11:03 AM #2923
- May 2016
- Annapolis, MD
- 523
08-24-2016, 11:15 AM #2924
Remember this is a clone of a machine from back in Jan 2012 when the market was very young. They were adding features to see how the market would take them. I would say it is actually nice having a dual extruder for the simple fact that you get spare parts.
One thing that you should be able to do with the new X machine is use the carriage for single extruder on the dual machine.
08-24-2016, 11:45 AM #2925
- Jun 2016
- Oklahoma
- 904
I decided I wanted a dual extruder simply from reading and the possability of two color prints but what I found is it has been handy to have PLA and ABS loaded at the same time so i can switch back and forth between whichever I need for the current print. The only downsid eis dragging an extruder but that goes away with proper setup.
08-24-2016, 11:46 AM #2926
- May 2016
- Annapolis, MD
- 523
08-24-2016, 11:53 AM #2927
Really with modern slicing software supports of the same material are usually just fine and generally remove without leaving too much of a scar, if any.
I have some PVA, but it isn't generally heat compatible with ABS. ABS is better with HIPS, but that is a chemical dependent support material to remove.
PVA is nice since it is just wash with water.
08-24-2016, 12:01 PM #2928
- Jun 2016
- Oklahoma
- 904
08-24-2016, 01:03 PM #2929
I got some at MicroCenter. Just keep it in a dry box as it sucks up water like a sponge.
08-24-2016, 01:08 PM #2930
- Mar 2016
- 29
Thanks for the feedback i am thinking i will remove the right side stepper and fan set up and make a shim up for the limit switch and if there iver is a time i need the second extruder its all still on the shelf i just have t reassemble it.
I am also pretty keen to get my hands on one of the 10mm rod upgrade kitds that jfkansas has to offer as my machine only has the 8mm z rods.
