Results 741 to 750 of 757
04-11-2016, 02:40 PM #741
The default is a 3x3 grid if you don't specify the number of points. So you would want G29 u4 T V4 or G29 P4 T V4 depending on where you got your code from.
You might want to try the RCBugFix file at www.github.com/MarlinFirmware/Marlin and turn on Mesh Bed Leveling. That might help you with the not flat bed.
04-21-2016, 06:30 PM #742
- Jan 2015
- 32
My Auto Bed Leveling In Action
Hi Roxy,
I finally got my auto bed leveling working. Here's a video demonstrating it:
https://www.youtube.com/watch?v=AnHCrnXoj9k
and here's the more lengthy post that includes a little more detail about the setup:
https://forum.lulzbot.com/viewtopic.php?f=16&t=4309
When will auto bed leveling with matrix be ready? I'll have to do some mods to my setup when that comes out.
Thank you very much for your help!!!
Mitch
04-23-2016, 10:56 AM #743
07-07-2016, 11:20 PM #744
- Jan 2015
- 32
07-09-2016, 10:42 PM #745
Hi Roxy,
I am having a problem getting my G29 to probe four points only. This is the BeckDac fork from about 15 months ago. If it would help to update to newer marlin I could do so.
I have the following in configuration.h. Thanks for any help!
Code:#define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 0 #define RIGHT_PROBE_BED_POSITION 110 #define BACK_PROBE_BED_POSITION 195 #define FRONT_PROBE_BED_POSITION 0 // set the max number of grid points per dimension // The G29 command defaults to 3 if nothing is specified. But setting the number of probed // points higher is very useful when getting a Bed Topology Report (G29 n 5 T) #define AUTO_BED_LEVELING_GRID_POINTS 2 // Uncomment one of the following four lines so the Bed Topology Report can produce a map // that relates accurately to your bed orientation. //#define ORIGIN_FRONT_LEFT //#define ORIGIN_BACK_LEFT //#define ORIGIN_FRONT_RIGHT #define ORIGIN_BACK_RIGHT #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 0 #define ABL_PROBE_PT_1_Y 0 #define ABL_PROBE_PT_2_X 115 #define ABL_PROBE_PT_2_Y 0 #define ABL_PROBE_PT_3_X 115 #define ABL_PROBE_PT_3_Y 190 #endif // AUTO_BED_LEVELING_GRID
07-10-2016, 08:56 AM #746
The default number of points (if you don't specify a number) is 3. You should be able to say: G29 n 2 to get 4 points (2x2) probed. Please be aware that it would be: G29 P 2 in the GitHub code. You should probably leave the
Code:#define AUTO_BED_LEVELING_GRID_POINTS 5
I do suggest you load up the RCBugFix when you have time. It has a lot of good stuff in it. And you will need to have your settings crossed over to it's Configuration.h format to run the Unified Bed Leveling that is coming out soon.
07-10-2016, 09:47 AM #747
Ok, I did the change to #define AUTO_BED_LEVELING_GRID_POINTS 5
I went to pronterface, ran G28.
when I sent G29 n 2 i got this error message:
Code:>>> g29 n 2SENDING:G29 N 2 Error:Line Number is not Last Line Number+1, Last Line: 0 [ERROR] Error:Line Number is not Last Line Number+1, Last Line: 0 Resend: 1
I'm searching for information on this error but not getting anything definite - Thanks for any ideas.
07-10-2016, 11:08 AM #748
Ok, I transferred all the information from configuration.h to the new one for RC6 bugfix and flashed it. I can't get it to home to the back right as my endstops are set up for (and as a lot of makerfarm I3v's are set for) previously there was a place to define the home as back right which I don't find in the new configuration.h. I saw somewhere a positive/negative homing direction setting, I will go look for that.
07-10-2016, 11:31 AM #749I went to pronterface, ran G28.
(If you look at what the error code says... You actually sent a Capital N. Probably a lower case 'n' would have behaved as expected.)
07-10-2016, 12:22 PM #750
If I ignore pronterface, which forces all alpha characters to UC, and use a gcode file with the LC n will it work? i'm on 1.1 rc 6 bugfix now. is the P implemented in rc 6 or yet to be changed?
I would go ahead and just try it but I'm still wrestling with the allowable probed area of the bed vs probe offset vs homing at the right back thing.
[....later]
OK, reflashed back to old DACB fork and ran a test gcode file with "G29 n 2" and it worked, probed four points as expected. I'm going to stick with this until I get a better understand the new bed layout setup in RC bugfix. Thanks very much for the help and for your work as a Dev!Last edited by TopJimmyCooks; 07-10-2016 at 12:43 PM. Reason: added info
