Results 2,201 to 2,210 of 4110
07-04-2016, 01:33 PM #2201
- Aug 2014
- 627
Good luck as it will not be cheap.
Rounding and lifting is what ABS does so all you can do is keep all drafts away and leave the bed at 110c. Don't lift the door up as that will create a draft. Use hairspray or a glue stick if you must and if that doesn't work use that AND brims.
07-04-2016, 03:19 PM #2202
- Jun 2016
- 21
Investors consider it bad for a company to have too much cash sitting around. They expect stocks to outperform money markets. Companies also buy others if they (the buying company) have over-valued stock due to high growth before its P/E ratio becomes more reasonable after the market stabilizes.
07-04-2016, 03:23 PM #2203
- Jun 2016
- 21
I love my borosilicate build plate, but with very thin ABS pieces, I was getting some lifting. A nice solid coat of Aquanet fixed that and seems to last for many prints.
07-04-2016, 04:05 PM #2204
- Aug 2014
- 627
Main reason why I despise Wall Street and investors and look out for venture capitalists as they should be shot on sight.
I firmly believe Wall Street has done more harm to the USA (saying USA since that is where I live) than good over the decades. Never go public with an IPO as the company is never the same again.
07-04-2016, 06:38 PM #2205
- May 2016
- Annapolis, MD
- 523
07-04-2016, 06:57 PM #2206
- Aug 2014
- 627
07-05-2016, 09:35 AM #2207
- May 2016
- Annapolis, MD
- 523
I ordered and received a roll of the new MakerGeeksCrystal Red PLA. Looks really great. I printed a spiral vase mode lampshade and it came out excellent. I used 230C & 75C decreasing to 60C with a blower after 1 (just before my blower died, Emily is sending a replacement.) This material seems a little more brittle than their standard Maker PLA, but the color is really cool. Reminiscent of candy apple red. I'm going to order a blue and a yellow before their sale ends today.
07-05-2016, 09:45 AM #2208
- May 2016
- 55
07-05-2016, 10:35 AM #2209
I'm inclined to agree, the more I look into it the more I think it's a firmware rather than hardware issue.
For what it's worth regarding the firmware resetting a couple of pages back. I've tried it today, it's seems to make no difference. Just what you'd expect it to do, back to how it was when the printer arrived.
07-05-2016, 11:01 AM #2210
- May 2016
- Annapolis, MD
- 523
Made a 40mm x40mm x 10mm solid object and the color is even more intense. Watch out though, I had printed on a build plate with glue stick on Boro glass. Even after it was cold I had to put the plate in water to get the part off. It was very thoroughly stuck.
I printed the spiral lampshade in my last post at 230C because I was concerned about the filament adhering well to itself in a single layer print. There was no bubbling in the lampshade at 230C. I then printed this square part at 210C, my go-to temperature for PLA and it seemed to come out fine.
Resin has changed after...
