Results 2,021 to 2,030 of 4110
06-28-2016, 07:44 PM #2021
- May 2016
- Annapolis, MD
- 523
06-28-2016, 07:48 PM #2022
- Feb 2016
- 360
06-28-2016, 07:48 PM #2023
- May 2016
- Annapolis, MD
- 523
06-28-2016, 08:10 PM #2024
06-28-2016, 08:18 PM #2025
- Feb 2016
- 360
I most certainly would.
Even for normal material (ABS, PetG, and PLA that is) I have noticed far less issues steming from feeding material since printing and installing these parts.
I have the stock large-tooth gear from Qidi still running on my left side and a low-pro gear on my right side. Both sides are running the feed assembly I linked. Also I changed spring on feed arm for the right side, using same length spring with just a tad less tension. Still enough push to feed great, but keeps soft stuff from getting choofed-up.
These are the only 2 feed gears I have tried so far.
06-28-2016, 08:39 PM #2026
- Jun 2016
- Oklahoma
- 904
06-28-2016, 08:40 PM #2027
- Aug 2014
- 627
What in the heck is low-pro gear?
06-28-2016, 08:50 PM #2028
- Feb 2016
- 360
06-28-2016, 09:01 PM #2029
- Jun 2016
- Oklahoma
- 904
06-28-2016, 09:16 PM #2030
- Jun 2016
- Oklahoma
- 904
I have the new QIDI running and it seems ok so far. I am now trying a print via USB but using my USB extenders that I mentioned some time back. It is two USB ends and a 25 foot CAT6 cable. So far it is working fine. If this works ok then it could be an option to be connected but still have the printer far from the PC.
