Thread: where to adjust x-axis?
05-11-2016, 08:56 AM #1
- Aug 2015
- 31
sorry for the stupid question.
but on my FFCP if i design something that takes up the whole bed, when it prints, i can tell it's shifted a little to the left.
the reason is
if i leave 1-2 mm of boarder, it prints right on top of the left edge of the glass, but not on the right.
so i think the x-axis is shifted to the left.
do i adjust this in the FFCP firmware settings? or in simplify 3d settings? (or both?)
thanks
05-11-2016, 01:01 PM #2
- Aug 2015
- 31
ah nm.
found it discussed here
https://groups.google.com/forum/#!to...ge/iBHocaDUes4
05-13-2016, 05:56 PM #3
- Feb 2015
- 91
Though that thread is for having the left extruder print 34mm to the left. It sounded like you were just off 1-2mm? If so, there's a X-offset setting in the eeprom which you can adjust (it's what defines the position of "home" when your start gcode executes an M132). But some start gcode (MakerBot Desktop for example) recalls the offset and then makes it useless by stomping on it with a G92 that defines the position to a fixed location, so to adjust it you need to change the start gcode not to do that.
05-13-2016, 10:21 PM #4
- Aug 2015
- 31
Resin has changed after...
