Results 11 to 14 of 14
Thread: Upgrade from makerfarm
04-15-2016, 07:50 PM #11
- Dec 2014
- Canada
- 498
if anyone knows where to get a 1900-2000mm closed loop belt for gt2 6mm wide, please let me know
Robotdigg only carries up to 1500mm
04-16-2016, 01:04 PM #12
- Feb 2015
- 70
Adam, check this out:
http://forums.reprap.org/read.php?1,445635,445905
This guy sews belts together. Not sure if you want to try this method... but it is an idea
04-16-2016, 01:11 PM #13
- Feb 2015
- 70
Just thought of another solution. Perhaps just use two smaller continuous loop belts with a "double" gear in between that both belts mount on to. This does increase cost and part count put allows you to "daisy chain" as many belts as needed without requiring exotic lengths.
Like this one:
http://www.dhresource.com/0x0s/f2-al...20teeth-20.jpg
04-26-2016, 11:35 PM #14
- Dec 2014
- Canada
- 498
i considered this option. but it would introduce a height difference between the belts. which is a problem.
Resin has changed after...
