04-17-2016, 08:49 PM #1
- Apr 2016
- 6
Glass Filament for Makerbot Replicator 2x?
Hi! I've never used a non-ABS material before, but I've been looking to try out a glass filament. The particular one I am looking at has the same width as the filament I'm using now, and melts at about 5 degrees celsius lower than the current temperature I'm using. Could using the glass filament ruin the printer in any way?
04-18-2016, 12:53 AM #2
- Sep 2014
- Brummen, Netherlands
- 265
I think you mean T-Glass (which is a plastic, not a real glass) ?
04-18-2016, 04:55 AM #3
There is no Glass filaments, there is TGlase (not TGlass...) and if it is the stuff you get here:
http://taulman3d.com/t-glase-features.html
Then as Ailbert said, that is plastic, it's not glass.
Considering Glass melting temperature is around 1400c, I don't think we'll be printing in Glass on our desktops any time soonHex3D - 3D Printing and Design http://www.hex3d.com
04-21-2016, 04:57 PM #4
- Apr 2016
- 6
Ahh, that's what I meant. I never realized the melting point of actual glass was so high! I was just thinking that it was some type of glass that had an especially low transition temperature (I know there are a lot of types of glass, like pyrex, so it didn't seem too alien that one could be a really low melting point). Thank you for your responses!
04-30-2016, 09:07 AM #5
- Jan 2016
- U.S.A.
- 15
Will T-glass work in a stock .4mm Replicator 2X nozzle.
05-17-2016, 05:53 AM #6
- Apr 2016
- 10
The advantage of a glass filled filament would be strength. But I doubt any Extruder except maybe a specialized one just for that filament would work. We use glass filled plastic in the plastic industry all the time. It makes the plastic really stiff, but it's also a little more brittle.
05-17-2016, 11:44 AM #7
