Results 1,011 to 1,020 of 4110
04-16-2016, 05:03 PM #1011
Really it is best to remove the left stepper and extruder right off the bat. I generally print at 80mm/s with one extruder and travel at 120mm/s or so. Even 1 extruder sags a little, but doesn't seem to affect final product much. For critical parts print on the far right or far left of the print bed, that is where the gantry has the most support to avoid ringing.
04-16-2016, 05:47 PM #1012
- Aug 2014
- 627
Which is precisely what I do with a printer is parts. Hmmm, so, how hard would it be to replace these 8mm rods with 10mm? I am unsure what it uses to hold them in so I do not know how hard the change over would be (I am getting a sinking feeling it would be a nightmare due to the bearing holders and everything made for 8mm). I am not as much worried about Z right now (I will be just not yet) as I am X, and to some degree Y.
I just saw a review done today on the latest Craftbot Plus and that sucker uses 12mm smooth rods for Z. Way overkill he said but I disagree for the stuff I like to do. Now that printer could easily do dual extruders without blinking if the other rods were 12mm but I think they are 8m or 10mm.
edit:
The XY smoothed rods are all 8mm.
The Z smoothed rods are both 12mm
04-16-2016, 10:23 PM #1013
- Mar 2016
- 45
Anyone who bought the latest version of the Qidi printer have a working starting script for S3D? I'm talking about when the printer starts up it just prints a goop at the right corner of the bed, I understand there is a script that nicely prints a line along the bottom of the bed before starting. I saw there are some posted before but I don't want to risk the extruder head slamming to the left like some have reported.
Thank you.
04-16-2016, 11:08 PM #1014
- Mar 2016
- 29
04-16-2016, 11:57 PM #1015
04-17-2016, 12:22 AM #1016
I find that if you catch it within 10-15 seconds after the wipe you can easily take the whole string + wipe portion off with a slight tug. Now it may be different for materials other than ABS and I can do that since I'm usually around at the starting stage of the print.
Sometimes when I left it on there until cooled, the string would bond to the printer wall or acrylic and it wasn't always the easiest to remove.
04-17-2016, 08:53 AM #1017
I created a new thread with the most recent script so it is easier to find.
http://3dprintboard.com/showthread.p...6116#post86116
04-17-2016, 07:46 PM #1018
Build plate and Z axis platform and guides all mounted up.
IMG_20160417_133319658_HDR.jpgIMG_20160417_133409039_HDR.jpgIMG_20160417_133428840_HDR.jpgIMG_20160417_133435459_HDR.jpg
04-17-2016, 07:56 PM #1019
04-17-2016, 08:03 PM #1020
- Mar 2016
- 45
Resin has changed after...
