Results 531 to 540 of 4110
03-13-2016, 12:56 PM #531
- Feb 2016
- 11
These are great! I posted mine to thingiverse (it was a 20 second sketch) but I imagine these will work better if these guide supports are doing anything. I'm collecting the accelerometer data today (put together the metrology system yesterday.)
http://www.thingiverse.com/thing:1412591
03-13-2016, 01:57 PM #532
- Feb 2016
- 11
03-13-2016, 02:19 PM #533
Posted mine as a remix:
http://www.thingiverse.com/thing:1412738
03-13-2016, 09:44 PM #534
- Feb 2016
- 360
Only the bit you can see when the nozzle is off since this started. But I actually changed out the PTFE tube on that side just 2 days ago with a fresh one.
I have been printing in ABS since mid afternoon, kinda thinking its not a mechanical issue. What yall use for heat settings with PeTG??
03-13-2016, 10:24 PM #535
Depends on the brand esun 230-240 and Makergeeks 250-260
03-14-2016, 01:48 AM #536
- Feb 2016
- 360
03-14-2016, 02:41 AM #537
- Feb 2016
- 11
Ran some test gcode with an IMU on the board. Was searching to see if the supports did anything, but found something more interesting. The build plates only vibrates on one direction change - in X, changing from left to right and for Y, going from front to back (all from the perspective of the control panel.)
I ran 4x 60mm bi-directional traversals at nominal 60mm/s in each direction and the build plate at mid-travel (with acceleration turned on) and got the data presented below. Since there are 4x traversals, I expected 8 peaks in each direction, but only found 4 (3 in Y because it doesn't do the last direction change.) The last blip that is common to all the channels is the end of a diagonal move to bring the head back to home. This anisotropic ringing behavior is apparent by the sound the printer makes and the visual shaking of the plate. The supports seem to cancel out a small amount of ringing, but that is beside the point. Maybe there's a bug in sailfish?
03-14-2016, 12:15 PM #538
- Feb 2016
- 360
03-14-2016, 02:21 PM #539
- Feb 2016
- 96
Do you guys have any tips on the tops of my prints being practically transparent? In Simplify3D I've tried upping the top layers from 2 to 3 and even 4 and it doesn't seem to make a difference. Even if I rotate a model and print it with a different orientation, whatever ends up on top will not be fully filled in. I've watched prints finish and it looks like it just does a few cross patterns (diagonal one way then again the other way) but not enough layers to prevent light from coming through. Any thoughts?
03-14-2016, 07:24 PM #540
- Feb 2016
- 360
Having problems getting ABS to stick today all of sudden. Cant print anything without a raft or the bottom layer corners will be rounded, and things will start coming off the glass. Using the same bed temp, same amount of hairspray.
Any ideas? Have only managed one print today and its past 7pm.
edit: Just had to cancel another print. This is the 6th cancel on same file today. Had just started on 3rd layer and corner peeling up bad, and all the edges rounded.
This print should not need a raft, the bit touching the build plate is a 95x95mm square.Last edited by Syd_Khaos; 03-14-2016 at 07:38 PM.
