Results 461 to 470 of 4110
03-07-2016, 12:55 PM #461
Ahh, I guess I just skimmed your previous post, didn't notice the T0 vs. T1 difference.
I'm not sure if it is an error. I copied and pasted it from bluemeane's post:
http://3dprintboard.com/showthread.p...ll=1#post81706
The only thing I changed was the "Move to wait position off table" line. The X-130 caused the carriage to hit the left side of the box. Changed it to X-110 and it worked great.
The "Load Right Extruder offsets" line is what I'm using and it is working just fine.
Code:M135 T0 ; Load right extruder offsets
03-07-2016, 02:26 PM #462
- Feb 2016
- 96
The scary thing about playing with G-Code for testing is it has a real physical effect on things whereas most code (that I work with) just is an output on your screen. So if you do something wild like G1 X-500 F9000, it's just going to slam the extruder head into the side of the case (like you mentioned). I don't want to break my machine!
03-07-2016, 03:03 PM #463
Yup, keep your hand on the power switch when doing it just in case. Unfortunately the capacitors in the power supply seems to take a few seconds to discharge so it isn't an immediate kill.
If you copy the code as I posted it, it should work fine... at least it does on my machine.
03-07-2016, 10:08 PM #464
- Feb 2016
- 96
Just tried it out tonight on a print and it worked great. Thanks Kludge.
03-08-2016, 12:29 AM #465
- Feb 2016
- 360
Tried my first dual color print tonight. Was easy to set up in S3D. But there is no infill. I double checked the settings and both processes have same infill value (25%). The print has no infill though, either in print preview or the actual print. There something I'm missing to get it to print infill when using dual-extrusion wizard??
03-08-2016, 12:33 AM #466
- Mar 2016
Hi all!
Getting pretty close to pulling the trigger on a Qidi myself (new to 3D printing), but have a favor to ask. From the product specs and pictures, I can't figure out what dimension is the width, height, and depth of the printer. Can one of you Qidi owners do me a favor and measure those dimensions for me? For the height, please include the acrylic top cover. And for the depth, please include with and without the rear-mounted spools. Thanks so much!
03-08-2016, 02:07 AM #467
- Feb 2016
- 11
Anyone else using PEI as a print bed? So far I've put about 20 hours on the printer, maybe 16 with the PEI. Awesome stuff. No prep and good adhesion at temperature. I haven't had a single print fail since installing the replacement bed. The original blue bed the printer came with distorted above the screw holes after only a few prints.
I ran a bunch of process optimization experiments with the ABS and a test structure I designed (with print speed, extrusion temperature and extraction multiplier as variables.) Turned out extraction was way too high for a measured filament diameter of 1.74 mm (average.) I dialed down extraction to 0.87 and that seems like a pretty happy and stable place. Slower print speeds got rid of some minor ringing - so far my only real complaint about this printer is the bed platform shakes pretty badly under big direction changes (yes, acceleration is on) but since acceleration is on ringing is mostly is exhibited in infill and square corners, and the latter's artifacts are very minor and can be dialed down by slowing down the perimeter printing speed.
03-08-2016, 07:30 AM #468
03-08-2016, 08:48 AM #469
- Mar 2016
03-08-2016, 09:28 AM #470
- Feb 2016
- 360
