Results 1 to 8 of 8
01-26-2016, 05:14 AM #1
- Dec 2015
- 15
Mini nail polish machine to smooth PLA?
Hi
I am trying to find away to smooth PLA model after print. I have tried sand paper and it works well, maybe too well that it scratch off some color from the surface which makes it does not look very nice.
My wife suggested me trying out this little machine but I am not sure.
Do you guys think it will work better than sand paper and will not scratch off the color?
I really can use some advices. Thanks alot guys.
01-26-2016, 05:19 AM #2
- Burnley, UK
- 1,662
You are not removing colour you are stressing the surface of the print. The colour goes all the way through. You can get the white to disappear by using a small heat gun carefully.
01-26-2016, 06:05 AM #3
01-26-2016, 06:29 AM #4
- Dec 2015
- 15
01-26-2016, 07:32 AM #5
- Dec 2015
- 15
Hey guys, if you dont mind I would like to ask another question related to the small heat gun. I am looking around and would like to know at what degree is good to remove the white thing after sanding on my PLA print? There's alot of 350-580'C heat gun, do you think that's over kill?
I'm trying to find something that offer around 200'C unless you think it's too low.
Thanks again.
01-26-2016, 07:41 AM #6
- Sep 2014
- Brummen, Netherlands
- 265
If you buy a cheap and cheerful digital hot air soldering iron you can set it to any temperature you like....
The cheapest option is a hand-held:
http://www.aliexpress.com/item/220V-...5-31a91901d343
I have one of these which I use mainly for re-work, but which doubles as a shrink-sleeve heater and plastic heater/smoother:
http://www.aliexpress.com/item/2014-...8-a5ac199cb0d8
The latter one regulates as low as 100 Celsius....
01-26-2016, 08:33 AM #7
- Dec 2015
- 15
01-26-2016, 11:01 AM #8
- Sep 2014
- 265
You mind sharing what is the lowest temp setting for the first one? Thanks
The second one is a truly temperature controlled device. That is you set a temperature in the display with the buttons (100-450 C), and it will regulate the air temperature to just that. Works well and I use that one for some electronics re-work.
Do check that you buy one with the right voltage for your area. Mine is 230V, yours may be different (you do not have your location set in your profile).
