Thread: Getting a 3D Printer
01-15-2016, 12:32 PM #1
- Jan 2016
So a friend gave me an old partially assembled/broken Prusa I2, I do not have the skills to fix it, it's also nearly 10 years old. I wan't to buy a new 3D printer possibly a Prusa I3 and then hopefully be able to use some of the Prusa I2 as extra parts. Im good at soldering, and have experience with arduino. I just don't have the skills to jump in and fix the Prusa I2, maybe after I learn about these printers I could.
Basically im asking if buying a new Prusa I3 is a good idea? Do they have good instructions on how to assemble? Im in the 300-400 dollar price range, I know it isn't a ton, but I think I can get a decent printer for the price. Im not expecting a perfect printer, im going into this knowing it WILL require soldering repairing and probably help from you folks on the forum. Would you recommend the Prusa I3? And if so where should I buy it in?
Located in the: USA
Also what tools would you reccomend that I need? (Other than solder, soldering iron, screwdrivers, pliers, and tweezers?
Oh yeah, also planning on printing ABS and im assuming a heated bed is a MUST.
What about this?
http://www.ebay.com/itm/3D-DIY-Print...gAAOSwnipWVHwV
Are they all created the same?Last edited by UltiFix; 01-15-2016 at 12:38 PM.
01-15-2016, 02:28 PM #2
Man, 4 threads down is one nearly identical to this one with great advice labeled "Need expertise before buying a first low cost 3d printer". Did you search for any threads about the i2 or the i3?
http://3dprintboard.com/showthread.p...ost-3d-printer
Just get a good i3. This is what you want:
http://wanhaousa.com/products/duplicator-i3-steel-frame
01-15-2016, 03:05 PM #3
- Jan 2016
Im not super good with arduino, but I know how to solder and use a multimeter easily, thank that's enough skill to run one of these?
Thanks!
01-16-2016, 03:05 PM #4
- Jan 2016
New member with print issue
