Results 1 to 8 of 8
12-25-2015, 09:24 AM #1
- Dec 2015
Holes on the SIDES of print (no holes on top)
12-25-2015, 09:43 AM #2
It does look like you are printing too hot. 205 C is a very common temperature for PLA.
12-25-2015, 09:57 AM #3
How fast are you printing? Could be too fast...
But Roxy's right, lower that temp....
12-25-2015, 10:03 AM #4
- Dec 2015
Roxy,
That was my first guess too. However, look at the picture. The one on the right was printed at about 190-200 C. It also look mat, which is strange to me.
Ignore the shifting problem.
Also, I didn't see anything like this on the pictures of printed-too-hot models.
Sebastian,
I'll try, that sounds reasonably, thanks.
01-07-2016, 07:48 PM #5
- Jan 2016
- 12
FYI:
I print PLA at 180-190 (depending on the overall size of the print) on a glass bed with hairspray as my 'glue'. Bed temp is 40, altho, I likely don't need it.
Could it be moisture in the filament, that is 'boiling-out' at the high temps?
01-08-2016, 02:12 AM #6
What speed are you printing at ? It might be that printing hot at high speed is OK-ish but if you print at lower temps you would need to slow down as well.
01-08-2016, 05:48 AM #7
01-08-2016, 06:09 AM #8
Try adding another layer of vertical shell as well.
Resin has changed after...
