Results 41 to 50 of 56
12-10-2015, 02:20 PM #41
Hey IDefINIte,
please stay on a professional level,
If you've followed this project at least to some extend, you'd know that the Peachy uses a UV laser (as pretty much every SLA-Printer ot there) and that the resin not only floats on top of the water but doesn't even mix at all.
Before ranting please consider having a look at what they've already achieved (The Kickstarter Updates). The prints do have a quality that is absolutely comparable to other printers way more expensive and although the Peachy Printer itself is a hackable product, the technology of floating the resin on water itself definitely isn't a fail/hack.
quertz
12-12-2015, 06:48 PM #42
- Sep 2013
- 308
12-13-2015, 11:07 AM #43
- Oct 2015
- 11
Iv have researched a bit, though the water technique has seemed speculative to me sorry. On that Im out on the Peachy personally. Way to much refraction with that and Im still hung up on keeping pure resin for later. Also maby I misremembered seeing a red laser. I assumed it was heat cured resin with the red beam. My mistake. I have seen blue/purple UV lamp techniques the entire time Iv looked up liquid resin printers. The correction was a bright note on my doubts of this printer, though I havent yet seen UV laser scanning so that might be fun tech for you guys. When I say doubts though I mean there was only one place for my 100 dolllars to go at this point in home printing technology and Peachy kept doing for me. By the way I do have a better technique that Iv sent to Rylan in the background. Its a two birds technique that I feel brings professionalism to their product. It spawned a backhanded compliment from him which was entirely professional in my eyes. The post I made to him was awkward but I felt it necessary to say what I said. Still do when i say i doubt the water technique. Maby querts that clears something up. I have a makeable concept in mind for what ill do on my end not a hackable one.
12-13-2015, 09:22 PM #44
- Nov 2015
- 15
If you did any research at all, you would have known that resin does not mix with water and therefore remains pure, that it can float on top of salt water, etc. By the way, quertz already told this to you: "resin not only floats on top of the water but doesn't even mix at all". But clearly you did not read his message carefully. And what refraction, what you are talking about? Peachy Printer prints on top surface of the resin, before hitting resin surface, laser beam passes only through the air.
Didn't you watch the video at peachyprinter.com homepage? It clearly shows how it prints: on top of the water floats pure resin, which is cured with UV laser. Also, this forum have many threads where UV laser and UV-curable resins are discussed.
Even if you actually have "better technique", it most likely will be more expensive than water and drip system.
It definitely was not necessary, because without knowing basic facts about Peachy Printer or even UV-curable resins in general you claimed that the idea has to die, even though it proved to be successful (just look at the Peachy gallery and watch the video) and inexpensive.Last edited by /dev/null; 12-13-2015 at 09:35 PM.
12-14-2015, 04:53 AM #45
- Oct 2015
- 11
ok fine but when i pack up my printer or drain my tank what do i do with the water? do i now need some sort of shaker device to dissipate the 2 liquids perfectly so that they dont collide during the next print? maby this is where the holes were comming from. this being used on the videos i watched is new ill check again.
Also these 2 collided for me
1 And what refraction, what you are talking about? Peachy Printer prints on top surface of the resin, before hitting resin surface, laser beam passes only through the air.
2 It clearly shows how it prints: on top of the water floats pure resin, which is cured with UV laser.
my though was the hack as i callled it broke "surface" or top layer tension by pulling the resin up with water. Its a great thought when purely physics based but terrible when in function practice.
yes and no. yes being more parts would be used to make my system. it streamlines the whole operation to me and is what id throw together in my home. no i dont think the cost of the Peachy would have to take any heat with the way id see the manufacturing put into place. alot of my post to Rylan was on the price points being thrown around. i did take sometime to explain the downside iv been seeing and put in a warning on the Freudian bubble about to be popped in this industry but i think i ended on good terms. he said $99 dollars and i was very intrigued about this tankless printer but i still wont invest into this as a water machine. the idea shouldnt die, it should live! and kick the ass of every company that didnt release this 99 dollar technology to the public. it just needs to be dialed in more to me.
12-14-2015, 05:47 AM #46
- Oct 2015
- 11
double morning post.
SORRY.
the saltwater concept completely left my mind after picking it up. i just rewatched "how it works" from their blog... go figure. i was thinking on using 100's of dollars of resin and re batching it. im split on methods here. the salt water is probably churning with laser heat and making its way into the resin making the holes. i wonder what comes ontop in a shake test :P. great cost saver though if a tolerance is made to stop heat and wave transference. i still find it hacky but yes its cheep and effective.
sorry to the community for being a lost forward in my posts. the concept of the Peachy is an industry killer i sware.Last edited by IDefINIte; 12-14-2015 at 06:44 AM.
12-14-2015, 09:29 AM #47
- 52
12-14-2015, 09:49 PM #48
- Nov 2015
- 15
You do not need any special device. There are many ways to remove water from the bottom, but simplest in my opinion is to use a pump. Either manual pump (less than $2 on ebay) or motorized. You do not have to remove salt water completely, it is OK to leave some water on the bottom. All you need is to bring down top surface of the resin so you could start printing again. You could easily remove remaining slim layer of salt water at the bottom completely, with syringe for example, but that's not necessary, you can safely store your resin with some water at the bottom, it will not harm it (only reason I can think of to completely remove salt water would be if you decide to use remaining resin in some bottom-up printer). What to do with removed salt water? Usually you would want to put it back to the top reservoir, if motorized pump is used, you could pump it up there with a push of a button.
Are you referring to mike_biddell's idea from other thread to use normal water as top layer, resin in the middle and salt water in the bottom? If so, you could have made it much clearer by using proper quotes and references. Yes, that idea would be a hack because to make it work properly you have to hack the software to take the top distiled water layer into account, not to mention other complications (for example, top water layer will evaporate slowly and change its thickness). But like other hacks/mods for Peachy from this forum, most users will not need them, and at the moment such ideas are intended only for small group of people who would like to experiment, and may not even give any obvious improvement.
I do not think that UV resin is conductive, so you would have to invent your own hack for the drip system intended for conductive salt water or replace it with something else. And using so much resin just to fill printing volume would be a waste, if you have so much money it is better to get many different resins and have them in many different colors, or just save a lot of money for something else if you do not need this. Also keep in mind that resin have limited shelf life so having too much resin is not a good idea. All of these are the reasons why Peachy uses salt water instead of enormous quantities of resin.
Since water and resin do not mix and salt is dissolved in the water but pretty much cannot be dissolved in the resin, resin will come up on top.
That's physically impossible. Resin is almost opaque for UV light, so UV laser affects mostly resin surface. Truly unpigmented resins usually have severe light bleeding issues and practically cannot be used without pigmentation. Some pigments are clear for visible light but almost opaque for UV light, so it is possible to have "tranparent" UV-curable resin. But the point is, very little or none (depends on the resin) of laser power reaches the water. And by the way, by heating up both water and the resin there is a chance to improve print quality and reduce probability of unwanted small holes/bubbles in the print (if you or somebody else would like to discuss this idea please post to Heated tank to mitigate surface tension? thread).Last edited by /dev/null; 12-14-2015 at 09:55 PM.
12-15-2015, 02:34 AM #49
- 219
I do hope my suggestion hasn't caused any confusion. A thin water layer on top of the resin, as dev/null has stated is NOT the normal operating mode of the Peachy. I was merely exchanging/kicking about, ideas about with other hackers to get their opinions (it's always good to talk). It's just something I will try when I get my Peachy. After all, just because something should work in theory, doesn't mean it will work in practice as refraction effects may rule it out.
12-16-2015, 06:33 AM #50
- Oct 2015
- 11
Im just going to put it out there during this back and forth. Im a non-functioning Schizophrenic. I have a decent grasp on the printer at this point and Im looking for some projects. Unfortunately this print qualtiy is sending me back to making my own printer. I sware I can do it on my on time frame. Old thoughts colliding with a new state.
By the way i got the heat/wave thought wrong. Its an easy one actually. Sorry for the confusing posts.
Correct me if Im wrong...
Step 1 Dump in resin for prints
Step 2 Water drip starts but has no room to fit under the resin. When acting like fluid substances will the 2 collide and in this case the resin is one denser and hydrophobic. So... When the resin solution is disrupted by the turmoil of the water drip the water pushes up before out and making an even elevator. Peachy is not getting a clean underlayer of water pushing up the resin. Instead water makes pockets inside the solution.
Step 3 Get lucky wither a pocket of water will enter your print or not.
I still am confused why some prints are glasslike and others seem to look like someone was trying to laser sinter the top of a moving resin Atlantic Ocean.
I suggested in the background a test with clear resin and colored water.Should be guaranteed if im now thinking the water lift right, somehow that escaped my mind.
Im going to call it reverse lava lamping. Lamping for short.Last edited by IDefINIte; 12-16-2015 at 06:51 AM.
Ender 3v2 poor printing quality
10-28-2024, 09:08 AM in Tips, Tricks and Tech Help
