Results 11 to 15 of 15
09-07-2015, 07:21 PM #11
- Jul 2015
- 11
Ok Mike , thanks
10-07-2015, 06:49 PM #12
- Oct 2015
Hi Mike, I am in the process of getting my MBP up to your install, currently running Par 10 going to upgrade now too Par 11, I noticed in 10, I could not get the Monitors Extended? is there a trick to this? I use the HDMI cable and it changes my res on my Laptop screen, but when I try to Extend, the same setup as you have, it just reverts back to "Show Only Display on 1"
if there is a trick, please let me know
Thank you
Steve
10-08-2015, 03:30 PM #13
In Parallels 11, you need to uncheck Use OSX Full screen option under Actions>Configure..>Full Screen>Options
I have use all displays in full screen checked too
Then maybe get a VGA adaptor, as I didn't have HDMI on mine, but if it's not set at 800x600 pixels in the Apple Display Preferences it won't work anyway.
You also have to do this in Windows, using the List All Modes options and select 800x600, & ignore the warnings.
Good luck
Mike
10-10-2015, 01:19 AM #14
- Oct 2015
Mark, I have successfully scanned using your system setup as a guideline, I am running parallels 11 and Running Windows 7 64Bit. The Extending Monitor deal was a lot of trial and error, but can tell you a simple find here, with the Mac OS X world.
Simply change the dual monitor settings on the Mac Display preferences, make sure that "mirror display" is unchecked and go to the Arrange tab and position the monitors side by side, it's at this point, I realized how powerful this was, it seems anything I did on the Mac preferences first, Parallels would follow suit, as soon as I did this, switched over to the Windows 7 side and sure enough, there were my dual monitors sitting there ready to adjust the resolution, of course "Extended" and I set the 2nd monitor up for 800x600 and Viola..... scanning, calibration, everything WORKED !!!!
my first scan
10-10-2015, 02:11 AM #15
Hi again,
Glad it's working. Like I said in earlier posts, you have to set the Apple Display Preferences in System Preferences. The trick is to Gather Windows and see them all. Then you change the resolution of the VGA/HDMI projector built into the Einscan-S and everything should be OK.
You'll know it's working because when you click on Arrangement you'll see the small screen next to your others, and your desktop picture will be projected by default.
Parallels looks at the default OSX system, but there was a bug on the earlier versions with extended desktops, and you had to uncheck Use OSX Full Screen.
I haven't managed to download the update, it seems to fail at the last minute.
Mike
PS Scan looks well resolved.
