Results 1 to 10 of 18
06-04-2015, 12:14 AM #1
- Jan 2015
- 306
New 24v system for heated bed not heating any faster?
Hey, I just got my 24v PSU installed and I wired it directly to my heated bed.
Originally, through my ramps at 12v, the bed took 13 min 50 seconds to get to 110C and would not sustain that temperature. I took all necessary steps to convert to a dedicated 24v PSU to run the MK3 on the 24v circuit. I measured the resistance of the 24V circuit and it was around 5.4 ohms.
I hooked my PSU directly to my heated bed, bypassing my ramps, just to see how fast I could get it to warm up. It is taken longer then the 12v through the ramps. What is going on? I soldered all connections, use heavy gauge high strand cable and for this test I am not even running it through a relay. I am completely puzzled.
Well, considering it is 5.4 ohms, thats only 104 watts. So, what should I do to put down more power. Can I run the 24v through the 12V circuit in the bed? Or if that seems too high, how about 16 or 18v through the 12v circuit in the bed? I am unsure what is causing the 24v circuit to be a flop, any help is appreciated.
Thank you,
06-04-2015, 12:48 AM #2
- Jan 2015
- 306
Just hooked the 24v system to my 12v circuit and it gets to 110c in 2 minutes 30 seconds LOL,
Ok, that works.
06-09-2015, 04:13 PM #3
- New York
- 66
Ohms law, Those heated beds have two resistors for all intense and purpose. if wired for 12v or 24v does not matter, they will put out nearly the same wattage. What I did to my own bed is I run it at 14v. Dropped the heat up time to to about 7 minutes to 105c. I am planing on running it around 30v and wiring it up for 24v to ease the load on my DC-DC upconverter as its basically limited to ~10A. At this point its putting out more than 10A on the bed. With that said, I run an unusually large power domain on my printer, ~700w at 110v or 1300w @ 220V. That gives me enough room to run everything else including a heater for my chamber and my web cam and a bunch of other accessories.
To put the math to work.
if your bed is like mike a MK3 heated bed which has a resistance of 1.4-1.6ohm at 12v or 5.0 - 5.4ohm at 24v
Here are the calculations
12.3v - 1.4ohm = 108W = ~8amps on the rail
14.0v - 1.4ohm = 140W = 10Amps on the rail
24.0v - 5.0ohm = 115.2W = 4.8Amps on the rail
24.0v - 1.4ohm = 411.4W = 17.1Amps on the rail
Running a mild boost should bring up the wattage while keeping the wires from going up in smoke.
35.5V - 5.0ohm = 252.05W = 7.1Amps on the rail.
It is much more friendly to be able to control the voltage on this kind of resistive load, as a bed that was meant to put out ~120w of heat running over 400w should have a very short life cycle. Even the mild boost I stated above would be taxing. I will probably set mine to run around 30v and keep the bed in the 180w-200w range.
As it stands my printer spikes to 475w out the wall socket when running full tilt and heating everything up.
06-10-2015, 07:07 PM #4
- Jan 2015
- 306
Well what I did was run the 24v supply through the 12V circuit. This thing gets hot, real fast.
06-10-2015, 09:56 PM #5
06-10-2015, 11:57 PM #6
- Jan 2015
- 306
06-11-2015, 07:17 AM #7
- New York
- 66
The thing is that it's not drawing 13amps.. more like 17-20amps. You could have a fire on your hands...
06-11-2015, 12:55 PM #8
- Jan 2015
- 306
The power supply is 24v 350watt, 14.6 amps max. Not sure if the PSU has a built in failsafe if it exceeds that current it shuts down or limits itself? I put a 15 amp fuse in line and it hasnt popped yet. I also used heavy gauge wire to power the bed. I am always near the machine when it is heating up.
06-11-2015, 01:12 PM #9
- Burnley, UK
- 1,662
Fuses are not a safe way to protect electronics. Your transistors will have been to Tibet and back before a fuse blows.
06-11-2015, 01:43 PM #10
- Jan 2015
- 306
Printing time- Is this right?
