Thread: First Layer Issues
05-02-2015, 11:28 AM #1
- Feb 2015
- 371
First Layer Issues
I am having some issues with my first layers. I tried adding ABL to help alleviate this but I am still having troubles. I have taken ABL off for now to try and master this problem before adding more. I have measured and double measured that my nozzle height matches what the printer is calling for using feeler gauges.
My layers do not squats together nicely and I have adhesion issues. Colin advises me to lower the endstop till it gets nice and squished. This doesn't seem like a good solution. I want the printer to actually match the controller.
So what settings do I have wrong? What should I be slicing at? I have my first layer set as .3 and the layer height is .2mm for now. I have the extrusion widths set at the defaults, 200%.
What settings should I start playing with to get a good layer?
05-02-2015, 07:23 PM #2
- Jul 2014
- Eastern Colorado
- 536
Even if your software is set up to perfectly match your hardware, if you aren't getting a good squish on the first layer, you have to lower the z endstop, which lowers your z=0, until you do get a good squish. First layer squish isn't something you can adjust in firmware/software, except by setting an offset or a certain start gcode.
05-02-2015, 08:54 PM #3
- Jul 2014
- 305
What size feeler gauge are you using?
05-02-2015, 10:36 PM #4
- Feb 2015
- 371
I move the nozzle tot .5mm and then use my .5mm feeler.
05-02-2015, 10:53 PM #5
- Jul 2014
- 305
