Results 21 to 22 of 22
Thread: G-Code alternative.
04-14-2015, 02:00 AM #21
While I understand the intellectual attractiveness of designing something new and more efficient, I really agree with Mjolinor.
A system that human people can read and understand by only memorizing a <100 commands language will always have appeal. I really wish your system works (I hate efforts going to waste). But practically, for the technicians doing the initial setup, debugging, maintenance and repairs on machines : their job is so much easier if they don't have to speak binary. If you don't mind catering to a limited selection of tech afficionados, forge ahead.
04-14-2015, 07:50 AM #22
- 314
Well, just because you called it out specifically, you CAN view a solidworks file for free. Download edrawings.
As for what we need for file formats, need is defined by each individual person. I only NEED a small number of file formats for my job and hobbies so if we're talking needs I could argue that anything else is unnecessary and everyone else should just learn to do things using the formats i like. Every format exists for a reason. Maybe that reason is an attempt to force people into proprietary software or maybe it's because that format allows for different feature sets than other formats. Without discussing every possible format individually and in detail there's no way to make that distinction. In the case of the OP's new format project, the clear benefit is file size. Now maybe that benefit is not something you or others are concerned with. If not, ignore it and go on using g-code or whatever you like. But for those like the OP that ARE concerned with file size, it's a significant change from the current "standard" that allows him and those like him to do something that is currently not possible, namely, caching an entire print on his machine without having to add additional storage space to it.
Resin has changed after...
