Thread: Nozzle size vs quality
04-06-2015, 01:39 PM #1
- 41
Quick question......
Would there be a noticeable difference in final print quality if printing at 0.1mm between using 0.4, 0.35 and 0.3mm nozzles ?
04-06-2015, 02:31 PM #2
- 462
You'll get a thinner extrusion width with the smaller nozzle, but it shouldn't make much of a difference to the actual layer height. If you're printing, say, a toothed gear the teeth will have better detail.
04-06-2015, 02:34 PM #3
- Dec 2014
- Canada
- 498
more likely to get a clog with a smaller nozzle. and your first layer height is shorter. makes it harder to calibrate
I tried running a .25 nozzle but the extra hassle and marginal increase in quality made me switch back to .4mm
04-06-2015, 03:54 PM #4
- 41
Thanks, was wondering whether to try 0.3 to see how I get on, but don't want to introduce issues.
04-07-2015, 03:19 AM #5
Actually there's a very interesting analysis done there : http://www.spiderbot.eu/en/blog/why-...mm-nozzle.html
I think what the author means is that a bigger nozzle will handle overhangs better.
04-07-2015, 07:43 AM #6
Excellent link, thank you.
Both using a wider (going from .35mm to .5mm) nozzle and using thinner (going from .2mm to .15mm or .1mm) layers improves the quality of unsupported overhangs.
And unless you're doing a very acute taper in the X/Y plane (like some gears), there is only a nominal difference in output.
And the duration of the print is reduced with the wider nozzle, as the article mentions.
Resin has changed after...
