Results 1 to 10 of 10
03-21-2015, 10:04 AM #1
- Mar 2015
- 6
has anyone tried the diamond black build plate
hey guys im new to 3d printing and keep getting prints warping. i have tried all the tricks in the book with no great success.
has anyone tried the diamond black build plate. was thinking of buying one but it looks amateur and don't want to get ripped off
here it is
http://www.ebay.co.uk/itm/Diamond-Bl...item339e3596ef
also do you have any new advice on preventing warping.
03-21-2015, 03:39 PM #2
what filament you printing with and which printer and what settings are you using and what surface are you printing on ?
Start there and we can probably help you.
03-21-2015, 04:00 PM #3
- Mar 2015
- 6
03-23-2015, 03:52 AM #4
- Mar 2015
- 6
ive just bought the diamond black plate. im hoping it does what it says it does.
03-23-2015, 04:41 PM #5
- Jan 2015
- 445
maybe im completely wrong, but it looks like the surface is pretty gritty... even a tiny imperfection will show on every print.
03-23-2015, 05:02 PM #6
- Mar 2015
- 6
apparently you need to use a raft, i tend to anyway so dont really matter with me
03-25-2015, 09:55 AM #7
- Mar 2015
- 6
the diamond black build plate has arrived the first issue i had was levelling the build plate as i had to tighten the screws all the way. apart from the i managed to print 4 parts today.
the first 2 parts was just the standard chain links that makerbot supplied on the sd card. printed them easy enough, then i printed the heart box that went fine.
but on a larger part i had to use binder clips as it wanted to pull the plate up.
all in all seems like a good solution to warping
03-25-2015, 10:15 AM #8
so the plate is flexible enough to be bent by warping.
That right there is a definite problem.
03-25-2015, 12:01 PM #9
- Mar 2015
- 6
03-25-2015, 06:00 PM #10
- 462
