Results 1 to 10 of 13
02-22-2015, 11:19 PM #1
- Feb 2015
Securing glass to bed without binder clips?
I just cut a glass for my CTC 3D printer and it was wondering if anyone had a way to secure the secure the glass to the bed. I have binder clips on right now but ti takes away from my print space and i have already had the print head crash into one. I was thinking of unseeing thin silicone pads like found under some electrics to prevent them from moving around. Any ideas?
02-23-2015, 06:07 AM #2
I currently use thin strips of kapton tape at the corners.
Works really well.
At some point I'll sort out some kind of magnetic atachment system. But tape the corners with kapton works really well.
That said I use blue tape on my bed, so the kapton doesn't interfere with the prints.
Bulldog clips just get knocked off.
02-23-2015, 01:11 PM #3
- Feb 2015
Hmmm I will try the tape as a short term solution but i like the magnet idea. next time at home i will take the bed off and see what that would take. I ordered some 1.5mm rubber feet so i will see how that works out, the heat should still make it to the glass. the only thing i'm worried about with that is the glass sagging in the center. Then again i could just put another foot in the center.
02-25-2015, 10:35 AM #4
- 93
see my post on the subject,
http://3dprintboard.com/showthread.php?10815-swapping-to-glass-bed
i have totally removed the alu bed, and placed the glass directly ontop of the heated mat, using the corner clips from here
http://www.thingiverse.com/thing:278540
and now i have a removable glass bed, need to get some more glass cut, then hot swappable beds
02-25-2015, 02:34 PM #5
03-01-2015, 10:32 PM #6
- Feb 2015
- 7
I printed d clips from Thingiverse that were made for the Flashforge and they work very well. They stay out of the way of the print heads also.
03-04-2015, 01:20 PM #7
- Mar 2015
- California
- 28
Yeah the corner bracts are the way to go. I've designed some new ones that are a little wider and have a little tighter tolerances and hold the plate a little more secure as a result that I will be uploading to Thiniverse in the next day or two. I'll post the link when I do.
03-04-2015, 01:41 PM #8
- Feb 2015
- 7
03-09-2015, 01:50 AM #9
- Mar 2015
- California
- 28
I just uploaded the newly designed Corner Brackets to Thingiverse. They have worked really well for me so far. They are the same ones that come with the kits on my website....
http://www.thingiverse.com/thing:715545
03-09-2015, 07:28 AM #10
Hmm wonder if they'll work with my aluminium plate, that's inly 3mm
Can't hurt to try as I can get as many alu plates made as I like. I can always reduce the vertical height of the clips by 2 mm.
Resin has changed after...
