03-18-2014, 01:13 PM #1
- Mar 2014
Makerbot replicator 2x build plate heating issue
Hey folks,
My uncle, whose an architect, recently bought a makerbot replicator 2x which I had to set up. After a couple of tries I was able to print the models provided with the printer without issues. However, when I wanted to pursue the testing with models downloaded from thingiverse I met an issue with the build plate. It wasn't heating at all and my prints ended messed up. Even when I pre-heated the plate, the temperature dropped during the print. The extruders were kept to the proper temperature but not the build plate. I insist that it happens only with the downloaded models and not with thoses provided with the printer. It is therefore unlikely that it has anything to deal with a hardware problem.
I guess it has something to do with the files which aren't giving proper temperature instructions to the printer, but I only have very superficial knowledge about 3d printing and I don't know how I could fix this. If anyone has had the same problem and was able to fix it or even know if it's due to the file or simply printer settings, I'd be glad to know about it!
Thanks for the help
03-28-2014, 10:14 AM #2
- Feb 2014
- Chicago
- 14
If you download files from Thingiverse, they are usually in an *.stl format. You then take those files and bring them into Makerware software that creates the *.x3g file for printing. When you are creating these *.x3g files, you have the opportunity to set the build plate temperature as well as other settings. I don't think the downloaded files are the problem. I also have Makerbot Replicator 2X and had issues with the build plate. Makerbot had to send me a new one due to problems.
04-02-2014, 01:25 PM #3
- Mar 2014
Thank you for the answer, I was able to figure that out however. Makerware was on the replicator 2 by default, and I hadn't set it on the makerbot replicator 2x. Hence the build plate not heating properly and ijts size being wrong.
12-29-2014, 09:29 PM #4
- Dec 2014
- Cincinnati
01-02-2015, 05:59 AM #5
- Mar 2014
New member with print issue
