Results 1 to 10 of 15
Thread: Test print
11-23-2014, 10:36 AM #1
Test print
Have a look. I just finished this with my beta model.
11-23-2014, 09:31 PM #2
11-28-2014, 08:07 PM #3
What about something like this:
http://www.thingiverse.com/thing:533472
Or even just a 10 mm cube... and then measure the dimensions with a caliper?
11-30-2014, 08:22 AM #4
Maybe you need to calibrate very carefully the nozzle temperature:
https://www.youtube.com/watch?v=FSOPsRiiOZk
Look at how much difference just a few degrees can make
12-03-2014, 06:19 AM #5
So that's abs on a cold build platform - with what looks like gluestick glue on it ?
Yeah the prints are a little rough, but abs ona cold build plate - that's very interesting.
Or does the micro have a hot plate ?
12-03-2014, 11:09 AM #6
A great start when new to 3D printing is PLA. I recommend no raft, no supports, and PLA as the way to go until you get confident enough to move on. I have been 3D printing for 2 years and never use a raft. If you need more surface adhesion on a segment of your model just draw some 20 mm dia. pucks that are the same thickness as your first layer and trim them off with side cutters.
I believe this user (Flyboy) has a printer with eccentric pulleys which is partly to blame for the quality.
12-06-2014, 10:41 AM #7
12-24-2014, 07:34 PM #8
I just got my printer back from the guys at m3d. It's been completely upgraded with production parts. I'll get some more videos up soon. I'm waiting for them to fix a bug in the firmware(they are working over Xmas on the code).
12-24-2014, 07:59 PM #9
Great to hear! Troopers they are, for sure. Looking forward to your results.
Can you take some close-up photos of the mechanical details? How rigid does the extruder feel? Is there a lot of flex if you grab the extruder and wiggle it?
12-27-2014, 08:34 AM #10
Hey,
I'm still unable to make new videos at the moment. There is still some firmware glitches sadly.
I may be able to do a short video of the mechanical details as it doesn't need to work for that.
Resin has changed after...
