Results 1 to 10 of 11
Thread: Wood is making a creaking sound
10-12-2014, 12:17 PM #1
- Sep 2014
I received my FlashForge Creator Friday 10/10/14. I have been printing almost nonstop since I got it. Saturday, its second day out the out the box, it started making a creaking noise and the back wall has started to flex up.
Is this normal for these? It hasn't affected my print quality but it is annoying to listen to.
Steven
10-12-2014, 04:45 PM #2
- Sep 2014
- 6
normal, but very annoying for sure
10-12-2014, 04:47 PM #3
- Burnley, UK
- 1,662
Every single bolt on my Wanhao was loose when I got it, at least half a turn on every screw. Since I tightened it all it does not creak.
DON'T PULL THE NUTS THROUGH THE WOOD.
10-12-2014, 05:11 PM #4
- Jul 2014
- 83
Given our proximity to Halloween, I would suggest, in the presence of creaking wood, not to go in any closets, and don't hang out with that geeky guy with the sweater tied around his neck. He's a goner for sure, and you don't want to tempt fate.
Unless you are that geeky guy with the sweater tied around his neck... In which case, good luck!
Cheers,
John
10-13-2014, 09:09 PM #5
- Sep 2014
10-13-2014, 10:12 PM #6
- Aug 2014
- Montreal, Quebec
- 576
Get some nylon locknuts, you'll just love to have never to deal with loose bolt!
10-14-2014, 12:55 AM #7
The best way to make the machine quiet is to put a block of foam between the floor of the machine and the fan that is blowing on the motherboard inside. That fan is where 99 percent of the crappy noise and vibration comes from. They put it too close and the top of the fan housing is resting on the roof, which on the flipside is the base of your print bed, or inner build space.
10-14-2014, 02:57 PM #8
Hell between the motherboard fan, the psu fan, the extruder fan and the cooling duct fan - I don;'t think a bit of foam would help me much :-)
And yep, regular tightening of the nuts is a good idea.
Actually it just occured to me you could tighten the nuts and then drop a wee drop of superglue on each one.
Would probably fix the nut loosening issue for good while still letting you undo them if necessary.
One more thing simnplify 3d doesn't cause my printer to vibrate so much on infill. that hexagonal infill of makerware is murder on the machine.
10-14-2014, 04:00 PM #9
- Burnley, UK
- 1,662
If you superglue the nuts then when the wood shrinks or the nuts pull through the wood a bit you will not be able to tighten them easily.
10-14-2014, 04:13 PM #10
the point is you tighten them before glueing.
And you can break the seal quite easily.
Why would the wood shrink to any significant degree ? It's plywood - so no coherent grain as such.
