Results 11 to 20 of 39
08-17-2014, 04:51 AM #11
- Mar 2014
- 50
Do you have a own design .stl file that we can look at and mabey even testprint for you?
08-17-2014, 07:01 AM #12
I currently cannot upload any of the files that I have, but I have found a model that has a lot of similarities in detail, overhanging parts, and thin parts.
http://www.thingiverse.com/thing:227534/#files
If you would be so kind to print this I would love to see it when its just finished printing with support on it; and of course with supports removed too.
Would also like to know which settings you used - or what trial & error had to be done to make a perfect model. Factor like time and material used is useful too.
Thanks in advance!
08-17-2014, 07:31 AM #13
- Mar 2014
- 50
08-17-2014, 07:36 AM #14
Well, I know that a SLA printer would grant more detail; but the material simply isn't that durable as I would like. Also; I don't see any problems with the file when opened in Solidworks or Blender.
Regarding the quality of FDM printers;
This is another sample of a FDM printed figurine that I found on Thingiverse and I found it's quality rather doable for post-processing:
http://www.thingiverse.com/make:86973
08-17-2014, 07:42 AM #15
- Mar 2014
- 50
The second file is world apart compared to the first one. This is my second print i did on my Zortrax.
08-17-2014, 08:00 AM #16
- Mar 2014
- 50
This how first file looks after slicing.
08-17-2014, 08:10 AM #17
08-17-2014, 08:40 AM #18
- Mar 2014
- 50
No i don't have any better pic. But this print in this thread are simular: http://forum.zortrax.com/index.php?/...79-black-swan/
08-17-2014, 01:17 PM #19
the second file would not need supports.
You'll probably find that you start modelling with the bottom up print process in mind.
And as geoff said the flashforge ('makerbot replicator dual' clone) - which is a dual head printer capable of using water soluble pva supports, or any other kind for that matter - would do you fine.
I think you could probably get one on ebay for around 500 euros.
Get it, get started - the more you print, the better your modelling for prints will get and the more experience you have the more knowlege you'll have for your next printer.
Yes there is a lot to learn, but it's more than worth it :-)
The sooner you start - the quicker you'll learn.
08-17-2014, 02:39 PM #20
Thank you for your reply. I wholeheartedly agree on getting started as soon as possible, but I also find some knowledge and fun in researching as much as possible up front.
Is there a reason that you'd suggest the Flashforge over other dual headed printers? Like the ultimaker 1 or makerbot for example?
