Thread: What is G29 used for?
06-29-2014, 03:25 AM #1
I haven't quite reached the point where I need to go into the G29 command, so I haven't been reading that threat. However, can someone give me a simple outline of what G29 does, and why we want to zero in on it?
Old Man Emu
06-29-2014, 07:40 AM #2
G29 is like the G28 command except on steroids. It probes multiple points on the bed and then uses that information to find the normal vector to the X & Y axis. It produces a 3 x 3 bed correction matrix that can be used by all the movement routines. When a specified coordinate (vector) in the GCode is multiplied by the correction matrix it produces a new coordinate in the new space that is properly located given the bed might not be flat.
