Results 11 to 14 of 14
Thread: Prints with holes
06-18-2014, 12:51 AM #11
I had to print something with a hole that had a "flat part" to it (like a D-shape), of 12.5mm diameter. I just printed a test piece, measured it out, and then as mentioned, just "fudged" the radius. Came out just about perfect.
For 3D printing just about any precision part, there is often some trial and error to get the diameters right (often depending on your printer as well as slicer settings), and you usually get the best fit if you can drill or file things a bit.
06-18-2014, 01:12 AM #12
I have had reasonable success adding the nozzle diameter to any internal hole radii. So, for a 10mm diameter internal hole printed with a 0.4mm nozzle I would create a hole 10.8mm wide, thats a radius of 5mm plus 0.4mm for the nozzle.
Not an exact art but often very close.
I think Slic3r and CURA both have the same issue where they seem to calculate the inside diameter of a hole as being the outer edge of the inner-most shell.
Much like drawing a small circle with a fat marker.
06-18-2014, 08:56 AM #13
06-18-2014, 01:04 PM #14
