Thread: Some MOD-t test prints
06-04-2014, 01:53 PM #1
- May 2014
- 60
Here's a couple of test prints I did recently on a MOD-t prototype:
The threaded rings were a test done with 0.3mm layers, and the springy-thingy was done with 0.2mm layers. Note these are just test prints - not things that will be in the New Matter Store .Last edited by NewMatter; 06-06-2014 at 01:34 PM.
06-04-2014, 02:55 PM #2
- Dec 2013
- Georgia
- 934
These definitely look good. None of the wobble that some have been worrying about. About how fast did these print?
06-04-2014, 03:07 PM #3
- May 2014
- 60
These were both done at 80mm/s speed settings, although the springy-thing probably never got up to that speed with all the direction changes.
This actually brings up an interesting point regarding speed. In a lot of (most?) printers, the top printing speed is limited by the maximum extrusion rate, which is directly related to the layer thickness. Printing at 100mm/s with 0.1mm layers doesn't really tax the extruder, but at the same speed with 0.3mm layers, the extruder is really moving. You never see these two specs explicitly coupled, but they should be.
06-06-2014, 06:48 AM #4
- May 2014
- 11
Holy cow! These looks great. The resolution here is incredible..... especially for a printer that I paid $249 for
