09-14-2022, 09:07 PM #1
- Sep 2022
- 7
Calibrating extrusion on Ender 3 Pro - First Time
Just got my Ender 3 Pro and I'm trying to calibrate extrusion for the first time. I've clearly made a mistake somewhere along the line so I'll lay out the whole process for troubleshooting.
- Downloaded Pronterface
- Connected over COM3
- Command -> 503
- Returned values M92 X80.00 Y80.00 Z400.00 E93
- Heated up the nozzle to 190 degrees
- Marked 120mm from where the extruder "eats" the filament
- Command G1 E100 F100
- The printer rolled it backwards and I ended up with 222mm of filament from the mark to where the extruder "eats" the filament. (this was the opposite direction of movement I expected but I could easily calculate the distance travelled)
- This means that 102mm of filament was pushed instead of 102
- New E-value calculated
- 100/102 *E200 = E196.08
- Command M92 E196.08
- Command M500
- Command M503
- Returned values M92 X80.00 Y80.00 Z400.00 E196.08
Now the article I read (linked here: https://3dnation504795197.wordpress..../#tempsettings) suggested doing this process a few times for the best results. So because of this, I repeated the test. When I ran it again it extruded 170mm of filament. Far past the desired 100mm. I've clearly messed something up but I'm not sure where.
I'd appreciate your guidance
10-05-2022, 01:46 PM #2
- Oct 2022
I used the built in configuration options on my Ender 3 Pro rather than doing it through the computer. Having the extruder at the default 93 resulted in less than 100mm of travel. I don't recall what the amount was, but I simply took 93 * 100 and divided that by the amount that was actually extruded. That gave me a value of 97.2 for the new E value. After doing that, it hit 100mm pretty much exactly.
all3dp has a good guide. https://all3dp.com/2/ender-3-calibra...-your-ender-3/
