01-18-2022, 02:19 AM #1
What is the largest sand 3D printer you have ever seen?
In my case, the largest 3D printer I've ever seen is the EasyMFG3DP-S2200?easy3dp-S2200.jpgEasyMFG3DP-S2200 Image
What is the largest sand 3D printer you have ever seen?Equipment Easy3DP-S2200 Build Box 2200mm×1000mmx1000mm External Dimensions 4400mmx2050mmx1900mm Precision ±0.2mm(200mm)±0.1%(L?200mm) Tensile Strength 1-4Mpa Surface roughtness Be superior Ral12.5 Gas Evolution Rate 12-20ml/g(850) Printing Speed 10-50 s/per layer Layer Height 0.1-0.5mm(can be adjustable) Printheads four piezoelectric printheads(Can be equipped with up to 8pcs) Specicification for printheads Length?72mm,resolution:360DPI File Format STL,3MF Electrical Requirements Three phase,380V,16A,50HZ Powder types Silica sand,quartz sand,precoated sand ,etc Last edited by EasyMFG; 01-18-2022 at 02:32 AM.
01-18-2022, 09:49 AM #2
