11-06-2021, 07:10 PM #1
- Nov 2021
FlashPrint 5, Unable to Print from Left Extruder
Good Afternoon All,
I have a FlashForge Creator 2 Pro Printer, two extruders.
I have updated to FlashPrint 5 as FlashPrint 4 is finished supportand recommended upgrading.
In FlashPrint 4 I was able to select which extruder I could use, in FlashPrint 5 I don't seem to be able to select which extruder I want for each print.
I have, when slicing selected the "left extruder", but when I go to print it goes to the right extruder.
I have checked the config, and have set this to the extruder I want, but still no.
FlashPrint was easy, before slicing select each item on the platform, left or right extruder, slice and the printer does what it's supposed to do.
I must be missing something here. Sorry if I am.
Regards Kevin.
12-01-2021, 03:20 PM #2
- Dec 2021
Solution
Hey Kevin,
just right click on your model. A pop-up menu will appear.
In this menu you can choose which extruder you want for printing your model.
After clicking on "start slicing", you can choose the extruder for printing your supports.
I hope this helps.
Cheers,
IceColdSushi
05-13-2022, 06:05 AM #3
- May 2022
of and on helps
