  1. #1
    Rubber/Soft Enclosure for 3D printed parts
    I am using Ender Pro for 3D printing a few cuboid shaped enclosures. To give them a good cosmetic and a softer touch I want to cover the surface with some sort of material (like shape fitting soft rubber material) Any recommendations?
  2. #2
    Jul 2014
    well there might be a spray you can use.
    But printing a thin cube with a soft flexible filament is going to be tricky even on a non-bowden printer.
    If you go slow enough it might work - but I wouldn't like to put money on it.
    A quick look shows various rubber sprays are available, here's a clear one: https://www.amazon.com/Rust-Oleum-26...1581040&sr=8-4
    That's probably your best bet.
  3. #3
    Technician Axl_Myk's Avatar
    Nov 2020
    Location
    The Hartland of Michigan
