11-11-2020, 11:18 PM #1
- Nov 2020
3D printing vintage cabinet hardware?
We moved into a house earlier this year that was built in 1911. It has the original cabinets with half-mortise locks, but about half of those are missing the locks themselves. The locks are fairly basic: an L-shaped plate, the bolt that holds the door closed, a square hole where the post from the handle slots into, and a sliding plate attached to a spring to return the locking/unlocking mechanism back to its starting position when pressure is not applied to the handle.Is this something that a 3D printed part could replace? Would it be durable enough to withstand opening and closing? These particular half-mortise locks are proving impossible to find.
192.168.o.1
192.168.0.1
tp link loginLast edited by parker76; 11-24-2020 at 02:14 AM.
11-12-2020, 07:48 AM #2
yep sounds like something perfectly printable and fairly easy to design and print.
you could probably use a standard spring retunr plate as well.
https://www.amazon.co.uk/Replacement...9SBN2CQMXEAQ33
Pictures would help :-)
11-12-2020, 04:42 PM #3
- 886
I'd like to chime in here, but I'm missing the big picture and probably the small ones too. Photographs are a great idea for something of this nature.
