07-09-2020, 07:33 AM #1
- Jul 2020
Artillery Sidewinder X1 New Printer
First of all hello to everyone
I have been doing a fair amount of research on purchasing a new 3d printed and sort of stopped on the Artillery Sidewinder X1.
From the reviews it is not perfect but at 400 USD no printer is.
Some of the possible upgrades needed I found are:
- extruder replacement with metal one
- ribbon cable prone to breaking (a 3d printed bracket can be created it seems)
- the AC heat cables under the bed also prone to breaking in time (also found some 3d printed bracket)
- spool holder is not the greates but can be relocated with some models from thingiverse
- add a metal flexible stick on plate for the bed (fulament seem to do one but out of stock)
Anyone else that has this printer can recommend it or any other upgrades to do for it?
I do need something that can print larger objects and I do need something that can go up to 300x300 length x width but 400mm height is a bit overkill (probably only need it to go to 200mm height-wise)
