Results 51 to 60 of 71
Thread: 3D Printed 3D Printer
08-19-2017, 12:37 PM #51
Finished the blower swap..
I have a thread just for this car here: https://www.superchargerforums.com/t...lown-z06.5348/
08-19-2017, 07:59 PM #52
- Jan 2016
- 326
Did I see what looks like a leaf spring under the front frame cross member at the other forum?
08-19-2017, 09:03 PM #53
Ya you did. It is the lightest possible solution and the specific implementation on the c5 and up corvettes does real good on the track. I put a set of track springs in my 5th gen(c5) corvette. they are the same springs. That can be seen here: http://www.digitalcorvettes.com/foru...d.php?t=264817
They have no weight to them. And the track or T1 springs I put in my car are really stiff. So stiff that as low as my car sits it doesn't bottom out and when I launch it the rear doesn't squat at all. The rear spring has 850lbs springrate.
08-19-2017, 09:18 PM #54
08-20-2017, 05:16 AM #55
- Jan 2016
- 326
What's the 3D printer that's printing the mount for power supply? What's the size of the build platform?
08-20-2017, 08:33 AM #56
That is Printalicious. My first home made printer. It has all the bells and whistles. 24v, Optical end strops. 6 stepper drivers, z probe for auto bed leveling, titan extruder, 400step/rev. or 0.9 degree stepper motors, and the 300x200 bed slides back and forth on 10mm linear rods. It can fit over 50mm more on each axis I just cant locate the correct size heatbed for my creation. The building of this printer can be seen here:
http://www.digitalcorvettes.com/foru...d.php?t=270130
And it's continued evolution can be seen here:
http://3dprintboard.com/showthread.p...Mixing-Printer
And here:
http://3dprintboard.com/showthread.p...twork-Printers
There is still one more round of upgrades I have ahead for printalicious. I have an mks gen 1.4 control board, mks solid state relay for the heatbed, and mks32 tft color touchscreen. I already have this setup on 2 other printers and I think it is just the way to go.Last edited by AutoWiz; 08-20-2017 at 08:42 AM.
08-20-2017, 10:23 AM #57
08-31-2017, 11:33 AM #58
08-31-2017, 01:08 PM #59
So the car is basically a knight 2000 - has it got the snazzy front lights ?
You know the ones that go back and forth and make the cool noise ;-)
09-04-2017, 01:47 AM #60
No such luck on the lights. just a bunch of red led halos. I have some more progress on the printer to share. I made a piece to house a lamp(led) and to hold the lcd screen..
This machine is looking more and more like a printer everyday. Just a few more small pieces to make and some wiring and this thing will be ready to make some stuff..
