Results 81 to 85 of 85
Thread: Simplify3D with FlashForge
09-10-2015, 10:27 AM #81
09-10-2015, 10:49 AM #82
09-10-2015, 11:41 AM #83
I select a printer: Replicator Dual
Load an object (that prints great using ReplicatorG)
Generate code
Send to print
Get that line in the front of the build plate
Goes to print the part and it just makes a mess...
Print plate leveled with application from the printer (maybe I should try the level function that comes with Simplify3D??? )
Using ABS
Printing over tape (same type of tape that I have used to print all the parts I have so far)
I will give it a try tonight and take photos and video to share.
Fist time, it was using settings that were hotter than what I was using before... so I took the temp down from 230 to 210 and the base plate to 110 from 120... still made a mess...
So no way that it works straight out of installing the software, at least not for me.
09-10-2015, 12:18 PM #84
ah - next time I'm i the workshop I'll send you my profiles.
basically you need to create a seperate profile for each head. and probably one for dual prints as well - not tried that yet.
I find when you use a specific profile for each head it all works much much better.
It seems weird that the gcode you change is just what head to use or not use, but it definitely effects other stuff as well. Don't know why.
The profile for my Klick-n-print that comes with s3d - drops the build plate abouta mm each layer.
Changed to custom rep dual profile - works perfectly. Yet nothing I changed referenced the layer height or z axis at all.
Also the knp has a weird size build plate that wasn't in the s3d profile. its 234mmx155x150
09-10-2015, 12:35 PM #85
