Results 11 to 20 of 109
01-17-2015, 10:26 AM #11
- Nov 2014
- 522
what is the error it throws when you try to compile it?
edit: nevermind i cloned the git repository again and dropped your configuration.h into it. I know what is causing it, I had the same issue. Give me a few to test an idea, and i might be able to give you a fix and If it works for you i'll try to push a fix to the main branch as well to permanantly fix it. I'm at work so i wont be able to test it... you'll have to be my guinea pig :-PLast edited by sniffle; 01-17-2015 at 10:38 AM.
01-17-2015, 10:44 AM #12
- Dec 2014
- Canada
- 498
Sounds good, thanks for your help!
01-17-2015, 11:58 AM #13
- Dec 2014
- Canada
- 498
Do you remove the manual adjustment springs once abl is working?
01-17-2015, 12:26 PM #14
- Nov 2014
- 522
The issue is in the grid point checking algorithm, that checks to make sure we aren't going to probe outside the bounds of the print surface. There is a preprocessor check that says you can't compare floating point numbers, and that is what is throwing the error. I may get Roxy in on this one sice i don't know C that well.
you can comment out that entire block of code, and it will compile/run but it may go out of bounds and the only way to do so is to manually press the endstop
I'm actually running Roxy's version of the firmware right now. I need to get this figured out...
I left my springs, I just don't adjust them anymore.
and speaking of roxy in case she reads this...
Roxy here is a link to the code in question as well as the error
http://pastebin.com/mJwSVMqF
01-17-2015, 01:12 PM #15
- Dec 2014
- Canada
- 498
ok i commented out that section and i flashed the firmware
I was able to home all axis but when i try and autolevel the prob tried to find Z off the table to far over X
01-17-2015, 01:38 PM #16
- Dec 2014
- Canada
- 498
i ended up moving my x and y ends stops in so that it wont overhang
but now when i try to home Z it says "z probe out. Bed"
01-17-2015, 01:38 PM #17
- Nov 2014
- 522
So i talked to @EvdZ|Ultimaker on the #marlin-firmware irc channel, he told me to remove the decimals to make it a whole number, the exact positioning of the probe is not critical. which somewhat makes sense and makes computations easier. and when i did this that fixed the problem.
this shoudl be your offset
#define X_PROBE_OFFSET_FROM_EXTRUDER -51
#define Y_PROBE_OFFSET_FROM_EXTRUDER 8
#define Z_PROBE_OFFSET_FROM_EXTRUDER -10
01-17-2015, 01:50 PM #18
- Dec 2014
- Canada
- 498
ok i will try that. i noticed that im recently getting upload errors
Binary sketch size: 162,052 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_recv(): checksum error
avrdude: verification error, first mismatch at byte 0x10f50
0x31 != 0xdf
avrdude: verification error; content mismatch
01-17-2015, 01:59 PM #19
- Nov 2014
- 522
That isnt the compiler it is to verify what you jsut compiled, that isnt something that i can fix or find out about. I compiled it no problem after changing the values
and EvdZ is one of the primary developers of Marlin right now, and obviously works for ultimaker as well
01-17-2015, 02:02 PM #20
- Dec 2014
- Canada
- 498
here is my current Config.h file
i will post a video of how the system is working right now
in a few min
Configuration.h
