Originally Posted by
RobH2
There are a couple of things you can do that you may not have found.
1. Click on the object and in the lower left you'll get transformation icons. The leftmost one is 'Rotate.' Click on it and you'll get two more icons that fly out above it. The top one is "Lay Flat." See if that corrects the model for you.
2. After you've clicked on the model, it will have transform gizmos around it. Find the one on the axis you want to rotate and while holding 'shift' left click and drag. You'll be able to drag in 1-degree increments.
3. Get a free program like MeshMixer and import your .stl. Rotate it and save it back out.
